Oriental's avatar
Jan 29, 2019
Geo filter: anyway to lock it “only dedicated servers” console
Hi i was wondering. Is there any option to only filter out dedicated servers? Might be an option in the next firmware. Because sometimes i still connect to a peer host.
Im very happy with the xr500 for so far. Working with it for the second day:)
  • Hi - great to hear you are enjoying it!
    That's a nice idea, the challenge we have is that classifying dedicated servers vs peers is quite tricky as games are often chopping and changing who they use to provide dedicated servers. So it's possible that some of the 'peer' hosts you are seeing might actually be servers. If you're playing BO4 (which I'm taking a guess that you are), then the easiest way to check is actually within the game itself. Go to the Network Settings section within the game and look for the host ID. If it ends in the letter 'E' then it's a dedicated server.
