josephquake's avatar
Feb 14, 2021
geo filter i have problems
How can I filter the games only by ping 20 as an example. I have had the problem that connects me with games with ping 60 I only want to play with people from my country only even though I have a geo filter in 1000 kilomero and I have selected in my country it continues to throw me with the Brazilians there are several servers in Chile of Call Of Duty Black Ops Cold War from chile to avoid placing myself on Brazilian servers
como puedo filtrar las partidas unicamente por ping 20 como ejemplo. he tenido el problema que me connecta con partidas con ping 60 yo unicamente quiero jugar con personas de mi pais unicamente a pesar que tengo geo filtro en 1000 kilomero y tengo seleccionado en mi pais me sigue arrojando con los brasileños hay varios servidores de Chile de Call Of Duty Black Ops Cold War de chile para no hacer eso de colocarme en servidores brasileños
  • One thing you could try would be to set your radius as small as possible and place it out in the ocean, then set ping assist to 20, reboot your game/console and search!
    • josephquake's avatar
      josephquake
      Tutor
      That was not to find games outside the selected geographic range. I tried it in warzone but it didn't work for me. I'll see if it works for me in cold wars. I am tired of blocking servers that I do not like their ping, they should solve this is very annoying apparently a 60 ping was within its acceptable range so it puts me on those servers not if you are a developer but I ask you to request something to be able to choose ping that one finds it acceptable in the game since call of duty is a low ping netcode game does not compare you the shots without a good ping to play.
      I can not block servers in real time because it takes too long to show me the information that is a serious problem
      eso no era para encontrar partidas fuera del rango geografico seleccionado lo intente en warzone pero no me funciono eso vere si me funciona en cold wars. estoy cansado de bloquear servidores que no me gustan sus ping deberian solucionar esto es muy molesto al parecer estuviera dentro de su rango aceptable un ping 60 por eso me pone en esos servidores no si eres un desarollador pero te pido que solicites algo para poder elegir ping que uno lo encuentra aceptable en el juego ya que call of duty es un juego de netcode de ping bajo no te compara los disparos sin un buen ping para jugar
      tampoco puedo bloquear servidores en tiempo real porque tarda demasiado en mostrarme la informacion eso es un grave problema
