Cayde-6
Apr 16, 2021Tutor
Geofilter not working
I don't know what happened, it worked perfectly until now.
I've tried everything:
- Changed the ping position
- Removed and added again the devices
- Updated to the latest version (V2.3.2.114) and returned to V2.3.2.108
- Tried to activate the Strict mode
- Turn off and on the router
- Factory reset the router
Also, after the factory reset, i've got another problem.
I can't allow myself. Instead of appearing my ISP, it appears another thing called "in-addr.arpa".
I have no idea of how to resolve this problem, i need help!
- Netduma-FraserNetDuma PartnerWhat's the problem exactly that you're unable to filter games? What game are you trying to play? You're not able to allow yourself as you don't appear on the Geo-Filter
- Cayde-6Tutor
Destiny 2 but i've recentely saw on another thread that you guys are planning to release a workaround maybe next week.
I love what you guys are doing, i appreciate a lot.
- Netduma-FraserNetDuma PartnerYes Destiny has changed their matchmaking system so it no longer works like it did. Not a workaround no but a cloud update so you should be able to filter servers like most games.
