xjay1337
Oct 03, 2018Aspirant
Getting sky to work with XR500
Hi
I am UK based using Sky Broadband - using Q - Fibre Max - and have a Netgear XR500 Nighthawk router and a DM200.
I have tried unsuccesfully to migrate the new XR500 into my network
Netduma_Jack
Oct 06, 2018NetDuma Partner
It should be a reasonably straightforward setup, so I would recommend doing this:
- Be 100% certain the Sky router has Internet if you connect to it
- Factory reset the XR500 and go through the initial setup again
I suspect that in trying to configure all these different settings you may have misconfigured the XR500. Factory reset should give it a clean start.
Netduma-Fraser
Oct 08, 2018NetDuma Partner
I would suggest getting the correct username/password from WireShark and inputting that into option 61 and see if that works. From what I can find online, this seems to be what is needed in order to correctly configure option 61.
