admael
May 24, 2018Aspirant
Guest network no internet access
My devices are not able to access the internet while connected to the guest network. The same devices work fine when connected to the main network
Any suggestions?
- Netduma-FraserNetDuma PartnerAre the guest devices showing as blocked on the Device Manager?
- admaelAspirant
No, it does not show up as blocked. Still having an issue with this
- Netduma_JackNetDuma Partner
I recommend you give NETGEAR support a call as you'll get a quicker reply from them than on here:
