TealITGyrl
Nov 11, 2025Aspirant
Has anyone figured out how to get Device Mgr to show in the Duma OS XR1000 Nighthawk?
Upgraded firmware from Version: 1.0.0.74 to Current Version of 1.0.1.82_1.0.67
I have rebooted, I've cleared cache, I've switched from Edge, to Firefox, to Chrome. I've tried all 3 in private mode. I've dumped all temp files everywhere. NOTHING seems to get this gosh darn page working. Anyone have any guidance?
- Netduma-FraserNetDuma Partner
A factory reset will definitely resolve it
- TealITGyrlAspirant
I've done a factory reset about 4 times this year. Each time the problem returns within a week. I shouldn't have to keep doing a factory reset for this to work. I think it may be time for a new device. I won't touch this DumaOS anymore. It's cool in theory, but there are too many issues. Thanks for the input though.
Are you accessing using HTTPS? Most browsers force it now which may be causing it, in which case disabling that for the interface would help. Otherwise if you're using Armor that may cause it as well.
Any progress on this?
Factory reset and setup from scratch?
Happens on a different PC?
