Kstauffer47's avatar
Apr 12, 2023
Heatmap not pinging for COD
I can ping other games but not Warzone 2.0. Why?
  • FURRYe38's avatar
    What model NG router are you referring too?
    Please post a screen capture of what your seeing.
    What browser are you using?
    • Kstauffer47's avatar
      Kstauffer47
      Tutor
      Xr500 and I'm using chrome.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        We need to update Ping Heatmap, it happens quite regularly that they change the servers used so it needs to be updated. It won't affect your ability to use the Geo-Filter or connect to servers though.
        Netduma-Fraser
        NetDuma Partner
        As above, everyone will have the same outcome, we'll get it updated on Monday
