Gradyj's avatar
Gradyj
Tutor
Feb 26, 2021
Help with slow XR500 speeds
Hello so I just switched to 1 gig fiber internet. I previously had 450 mbps charter. I ran a speed test with charter on wifi (5Gz) right before the Fiber installer showed up (3pm), I got 442 down, 21.5 up 14 ping and 2 jitter. After he installed the fiber, I got 352 down, 239 up, 4 ping and 1 jitter.
All over 5Gz wifi.
The ethernet results for the fiber are 901 down, 237 up, 14 ping.
Why would my router be SLOWER on WIFI with 1 gig fiber than it is with 450 mbps charter?? The router is only about a month old and is up to date. Thanks in advance.
  • I would factory reset and go through the setup wizard so that it can adjust to the new connection you have, then see if it performs better.
    • Gradyj's avatar
      Gradyj
      Tutor
      I tried. It actually made it worse. I'm down to under 300mbps over wifi on 5GHz.
