Alvarommb's avatar
Jun 26, 2019
High priority traffic not detected PS4
Hi, My XR500 won’t recognize my gaming console (PS4) as high priority traffic, the red dot doesn’t turn off while playing, I’ve try to put ports manually with no luck (3659 udp/tcp) and then (1-65535 udp/tcp), also try adding the gaming console but that also didn’t work, what can I do?
Thanks
    • Netduma_Alex's avatar
      Netduma_Alex
      NetDuma Partner
      Are you sure you're adding the correct device? Remember that Ethernet and Wifi connections from the same console will appear as two different devices in DumaOS. Find the correct one and name it something unique.
