mach2512's avatar
mach2512
Follower
Dec 18, 2018
Hot to Set Up: XR700 with SX10
Hello there,
     Wondering if pairing the XR700 with the SX10 will not allow me to use the features of geofiltering and QoS. How can I connect both of them (for the extra LAN ports) wihout losing the XR700 features? The reason is because SX10 also has QoS, and I am not sure if that will also create conflict.  Thank you!
  • FURRYe38's avatar
    Can the features on the SX10 be disabled, if so, then just connect it to one of the open LAN ports for additional LAN ports where needed. It would be best to use the XR for doing any management needs and let the SX just be a extra LAN port switch.
