kc717's avatar
kc717
Follower
Nov 26, 2022
How do I set up 2 xbox's using seperate live accounts on a xr500?
Looking for a way to connect 2 xbox one's using separate live accounts to e able to play online games at the same time.  Using a XR500 with updated frmware.
Thank you
  • FURRYe38's avatar
    Just connect them. WIred or WIreless. Refer to the MS or xbox support pages for help and information on connecting game consoles to the router.
    I recommend setting NAT Filter to OPEN on the XR router. Under Adavanced tab/WAN Setup.
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Begin with the Quick Start/Installation Guide.
  • They can play at the same time, that's no problem, is there something you're specifically wanting to do with them?
