tech50's avatar
tech50
Follower
Jul 19, 2021
how to fix xr500 to connect to internet
My expiernce with my XR500 netgear nighthawk gaming pro router was a storm that knocked out my router's connection to the internet. How do you fix this problem?: Problem solution i came up with was using my ac1900 nighthawk smart wifi router model r7000 to fix the problem at hand. After i fixed the problem that i had with my XR 500 gaming pro router is that i had to change it back to my ac1900 nighthawk smart wifi router model r7000 to fix the problem and there's never been a problem since
1 Reply
  • If you hook the XR500 back up again, I suspect you'll probably have connectivity again unless there was some damage caused by the storm. If you have any further issues let us know.
