hboutlaw77
Feb 18, 2024Follower
how to get past initial dumaos screens
I've setup my netgear router using the dumaos setup wizard. It's stuck in this loop to prioritize gaming or not. I cannot get past these screens to the desktop and configuration setup screens.
I've already factory reset the router knowing netgear always seems to have issues when first installing and updating firmware.
How do I access the actual router setup?
- Netduma-FraserNetDuma PartnerWhich router is it you're using exactly? Use another device to access and see if you can get past that point
- hboutlaw777Aspirant
ax5400 don't have another computer with an ethernet port.
I did clear the cache and used a different browser
- Netduma-FraserNetDuma PartnerThe XR1000? You can use WiFi, can you provide a screenshot of the exact point you're stuck at please?
