P111
Oct 27, 2018Luminary
How To Set Priority For Unrecognised Games?
Am I correct in saying that a game should show as "High Priority Traffice Detected" on this picture?
What do you do if it doesn't? I guess it needs to be setup manually, but how do you do that? I mean the information it needs doesn't seem to be available.
- P111Luminary
Sorry this is in two posts I seemed to have issue with formatting! But it doesnt actually seem to be prioritising anything despite priorities being set on the pc.
- P111Luminary
Anyone? There is an advanced option so there must be a way!
- Netduma_JackNetDuma Partner
Traffic Prioritization automatically detects all console traffic, and most popular PC games. If you're not seeing it being detected, then you can manually add the ports the game rules. Click Add Device in the bottom left panel, then choose advanced. You can then give the ports from the game (Google these if you are not sure what they are).
See the final section of this guide if you get stuck: http://support.netduma.com/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos-step-3-
