Brainbleach
Sep 20, 2019Star
Hybrid-VPN DNS leaks
I'm having an issue trying to setup a hybrid-vpn connection on my xr500. I can get the VPN to work but the router still uses my DNS servers setup for my normal connection. In this case it's googles DNS 8.8.8.8. How do I specify the VPN to use the VPN's DNS servers? Without the DNS servers being correctly setup the VPN connection isn't secured.
You can manually set custom DNS under Setup/Internet.
Yes but how does one use the DNS server provided by the VPN service with the VPN connection but use my "regular" DNS servers for my non-VPN traffic?
- Netduma-FraserNetDuma PartnerWhat are you trying to apply the VPN to specifically? Could you provide a screenshot of your entire VPN page please?
