Raulsalgado140's avatar
Sep 28, 2019
I have xr300 and most of the menu wont show up like qos or the geo filter. I'm stuck with settings
Iv'e tried to see if it was just happening on chrome but it's also happened on other internet browsers too. Can someone please help.
  • FURRYe38's avatar
    So FireFox or Opera experience same thing?
    Be sure to clear ALL browser caches, exit then re-launch the browser and then navigate to the routers web page.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Definitely perform a factory reset either from Settings > Administration > Backup Settings > Erase if you're able to or hold the reset button in the back of the router down for 30 seconds.
