MJoplin
Mar 30, 2020Aspirant
I increased my ISP speeds - when I speed test from the Router I get good results, My Cat 5e Ethernet
I pay for a pretty decent speed from my ISP (just bumped it up). When I do a speed test from the Router, I get the full 20MB speed however, my laptop which is connected via Ethernet 5e cable still only gets 3-4 MB/s. There must be some configuration within my Nighthawk Triband R8000 on the latest firmware that let's open the throttle on wired Ethernet and let it do better. Help?
did you setup qos on the R8000P?
I've heard of prior settings being retained even through a reboot.
Have you tried a simple factory reset and re-install?
