josephquake's avatar
Feb 15, 2021
I'm tired of blocking servers
I cannot block the servers that I do not want to connect in real time because it takes too long to show me the information I bought the router to have a good time I am all the time disconnecting myself from the games and blocking servers that I do not like if they could show me the information in real time it would be solved the problem I have to connect to the game that I do not want since it takes so long once inside it just shows me the server information
no puedo bloquear los servidores que no quiero conectarme en tiempo real porque tarda demasiado en mostrarme la informacion yo compre el router para pasarla bien estoy todo momento desconectandome de las partidas y bloqueando servidores que no me gustan si pudieran mostrarme la informacion en tiempo real se solucionaria el problema tengo que connectarme a la partida que no quiero ya que tarda tanto una vez a dentro recien me muestra la informacion del servidor
  • You don't need to block servers manually at all. All you need to do is set your radius and then it will block anything outside and allow everything inside automatically.
      • Netduma-Liam's avatar
        Netduma-Liam
        NetDuma Partner
        Have you tried setting up Geo-filter as Fraser suggested?
        That will automatically block most of the bad servers you could connect to and drastically improve your experience.
