RBosel
Aug 18, 2019Aspirant
"Innovative" DumaOS
Any idea when the DumaOS will work as advertised? Is anyone actually able to use this software? I have had this router for almost a year and the dashboard loads like I am using dial-up internet. Any firmware to fix this? Anything at this point would be nice since I paid over 500 dollar for a standard router at this point seeing how I can not customize anything like I was told I would be able to.
Ask Christian_R for the beta. I also saw this slow UI issue when I had a XR700.
- Netduma-FraserNetDuma PartnerWould suggest beta firmware but also to double check are you trying to access the interface using HTTPS? If so then HTTP should be much faster.
