GraphicFrost
Nov 18, 2019Aspirant
Intermittent latency issues and packet loss Nighthawk X10 R9000
I'm having packet loss issues with my router. It just expired passed it's manufacturers warranty. For the price of this thing I can't believe in just around 1 year it broke. I haven't had these issues until recently.
I've had Xfinity come out and update all the lines outside the house and confirm there isn't an issue on their side. I upgraded our gigabit modem as well. Without the router i'm hitting 900 megs down and 75 up. With the router I see the same but when I'm playing games i'm experiencing massive packet loss.
Router has the latest firmware as well.
What are my options?
When you say " With the router I see the same but when I'm playing games i'm experiencing massive packet loss. " it makes me think the issue is intermittent. Its hard to rule out a modem/line issue if the problem is intermittent and strickly say its router. Its even tough to narrow it further because many things can cause intermittent problems or latency issues.
What version is this latest firmware?
What modem are you using?
When you're gaming, is it over a hardwire connection or wireless?
If its wireless, which radio are you using? 2.4ghz or 5ghz?
Do you have a screen snip of your modem connections page show both the upload and download?
Is its specific games or a couple games? Is it only when you're gaming?
Are you using qos? or any other traffic monitory setting that you're running?
have you tried a factory reset since you've had your gigabit setup?
Or some games require specific settings?
https://kb.netgear.com/23020/Opening-ports-for-internet-games-and-applications-on-NETGEAR-routers
- GraphicFrostAspirant
- I don't have the firmware number as the router i unplugged, however the firmware is the latest when I checked a few weeks ago. I've been out of the country until now. If this is manditory for help Ill plug it in, however it's completely up to date as per the UI.
- It's not the modem or my lines. I have xfinity out to test the lines. If I remove the router the packet loss issues goes away.
- my down speed is 956mbps consitantly upload is roughly 56
- Wired obviously
- The issue is intermittent but it happens consitant enough to where I can diagnose the issue. I've had the router for over a year now. As soon as I add the router, set the modem in bridge mode. About 10 min into gaming every game I have is unplayable. I have confirmed packetloss multiple times
- It happens when streaming, playing games etc. It's very noticeable when it happens. I could be gaming for about 20 min to an hour then it is non stop packet loss. Ping skyrockets from 38 to 100-200 and games like rocket league report packet loss. If im streaming it kills the feed sometimes.
- I have factory reset it twice and I have updated firmware to latest from an older version. Issue still maintained.
- I do not use QOS, I do not want to use that either.
- I have NEVER once had a problem until last month.
A couple things off what you said.
1. you said you put your modem in bridge mode. Makes it sound like a modem/router combo device. Not all isp's are that great with "bridged mode". You're relying on your isp's device to be functioning properly. its also why I asked what modem it is. What model is it?
2. The latest isn't going to be the latest forever. A number does help. As well as potentially a firmware update could be causing your issue. Expecially if you've had it >1 year and the problems only happened in the last month.
3. Saying you've had xfinity out to test the lines doesn't mean a lot. There's crappy technicians out there as well as they only care about getting out of a house. I've had bad techs or one's who don't know whats going one. When you're having issues, you have to investigate every avenue. Not just "it isn't my lines because my ISP (who wants to function as cheap as possible) told me so". The screen snip of your connections page of your modem (upload/download signal strengths helps) and the logs help us to help you.
4. "wired obviously". It isn't obvious. its why we ask. Not trying to be a **bleep** but things might see obvious to you but its better to put it in your statements because we don't know your layout or exactly whats going on. More details are better than less for troubleshooting.
5. What's changed in the last month? You've had it over a year according to your statement. What changed in the last month? modem? coax line? location of the modem/router?
7. You said what games and streaming its happening on. But is it all devices or just one? Again, wireless/wired and what devices.
Something to try? From the sounds of it, you have a modem/router combo device based off your bridged mode statement. Turn the routing functions back on for the combo device, disable wifi on it, and place your router in AP mode.
Another thing you could try would be to downgrade the firmware a version or 2. Maybe something changed that caused issue with your device.If you do this, make sure to do it over a hardwired connection and reset afterwards. manually reinstall it and don't use a backup configuration.
BTW this would be the forum for your router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
