jesma
Jan 19, 2024Aspirant
Internet Down Nighthawk XR500
Hello all, I write to you with troubles. Our Nighthawk XR500 suddenly just doesn't work anymore. The internet light just flashes orange. We reset the modem and the router several times. I even did a factory reset on the router and it seemed to work again... for a few hours that is. Same issue. I don't really even trust it anymore. Any chances you had a similar problem?
- Netduma-FraserNetDuma PartnerWhen you don't get internet do you still have access to the interface? If so could you get the logs from the System Information page when it happens please?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
