iTzPedroHDi's avatar
iTzPedroHDi
invalid rpc request
I bought a Nighthawk XR1000 and i keep getting this error invalid rpc request message i try reseting to factory settings updateing fireware but it say im in the newst fireware
  • How did you reset the router exactly? Does the error appear by just loading the page or after changing a setting?
    • iTzPedroHDi's avatar
      iTzPedroHDi
      reset to factury setting my holding the reset button with a paper clip for 10 sec
      i get the massage ever 10 to 15 sec also the http://192.168.1.1/ takes too long to load up
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        You will need to hold the reset button for 30 seconds, then release, wait 2 minutes for it to reboot properly then access it and see if it's working properly.
