rick146
Apr 02, 2025Tutor
IPv6 - cannot change the setting
 I am having an issue with making the router use IPv6 and changing the setting in the DumaOS router login software.  I go to Settings>Advanced settings>IPv6 and there the internet connection type is s...
- Apr 02, 2025
Might give newer FW a try:
Load it up, factory reset and set up from scratch. I might give the Ipv6 setting a try with out the router connected to the ISP modem. See if the setting will persist after enabling it using FireFox browser. If it does, then connect the router to the ISP modem.
Apr 02, 2025Guru - Experienced User
Whos your ISP?
What browser are you using? Happens with different browsers? Try MS Edge or Firefox?
- rick146Apr 02, 2025Tutor
ISP is Spectrum
Modem is Spectrum's modem model # EU2251 Docsis 3.1 eMTA, no brand name found on modem
Using Google browser, then attempted as per your reply on Firefox = same results and Microsoft Edge = 404 not found after many attempts.
