ROBODOG
Jul 14, 2018Aspirant
IPv6 Manual DNS boxes
So I am manually trying to put the ipv6 cloudflare numbers into my router. The cloudflare dns numers are a series of 4, 4 digit numbers (2606:4700:4700::1111). But in my settings there are 8 boxes for each ipv6 dns numbers (_:_:_:_:_:_:_:_) with no double colon, I attached a screenshot of how it looks below. I currently put the numbers in the first 4 for primary and secondary. Once I hit apply the rest of the boxes filled with 0s. Is this correct or am I doing something wrong. I'm somewhat new to this so forgive my ignorance. Thanks for any help.
- Netduma-FraserNetDuma PartnerCheck to see if your DNS has applied: https://ipleak.net/
If not maybe worth calling Netgear support- ROBODOGAspirant
Thanks! Using the link looks like its nor working. I still havent figured it out or heard back from Netgear.
- Netduma-FraserNetDuma PartnerDarren can you help out with an update on Robos case?
- YouTwittFaceAspirant
- Netduma-FraserNetDuma PartnerI assume It would be like this based on the previous example
2602:fcbc:0:0:0:0:0:ad
2602:fcbc:2:0:0:0:0:ad
