Goretech
Apr 22, 2018Guide
Issues with certain TVs / tv devices needing to goto check network status before it gets internet
A couple weeks ago I replaced my Nighthawk R7000 with the Nighthawk XR500. At first I had disconnect issues but those are resolved I believe.
The main issue I am having now is certain devices when powered on will not connect until I tell it to refresh its connection by using Network status. This did not happen with my R7000. The one device it always happens on is Samsung - 43" UN43M5300AFXZA
Any thoughts what would cause this? I tried wired and wireless with the same issue. I brought in another TV, with built in Roku, and it works fine in the same spot. Not sure what the R7000 was doing to always provide instant on internet to the Samsung TV but it is very annoying that the XR500 doesn't.
I got a Linksys wrt32x and since I have a killer nic in my gaming PC, it is great. It fixed my tv issue too. Its 33% off right now, so saved a $100 too.
- Netduma-FraserNetDuma PartnerDoes the TV use a standby/instant on feature? If so disable that then when you turn it on does it get internet immediately?
