gnemelf
Jul 02, 2019Star
Issues with XR450 and Destiny 2
I have the Nighthawk XR 450 firmware V2.3.2.40 and yes I have done the reset with all ethernet cords disconected.
I am having serious issues with destiny 2 for PC, I can play for about 15 minutes till I get disconnected from the router, have to unplug ethernet cord and replug to get connected back to the router. I have qos set for the specific ports, geofilter is correctly setup and not on strict mode and set to ps4. I have a netgear CM600 modem and I have verified that it is not causing the issue, I have zero issues if i plug straight to the modem but I need a router for other pc's and devices in the house.
My logs have alot of this
[DumaOS] DHCP lease change., Tuesday, July 02, 2019 17:33:20
[DumaOS] DHCP new event., Tuesday, July 02, 2019 17:33:20
[DumaOS] DHCP lease change., Tuesday, July 02, 2019 17:33:18
[DumaOS] DHCP new event., Tuesday, July 02, 2019 17:33:18
[DumaOS] DHCP lease change., Tuesday, July 02, 2019 17:33:06
[DumaOS] DHCP new event., Tuesday, July 02, 2019 17:33:06
and
[DumaOS] Error parsing line in ARP table: 'fe80::217:10ff:fe84:eddd dev brwan lladdr 00:17:10:84:ed:dd router STALE', Tuesday, July 02, 2019 17:33:11 [UPnP set event: del_nat_rule] from source 192.168.1.2, Tuesday, July 02, 2019 17:33:09
when the issue seems to happen I don't know if the 2 are related. Hope for some help because this is the only game I play and currently cannot play due to how the router is not performing. I'm pretty much at about the point of going and buying something else from elsewhere to find something that can work with the 1 game I play.
I has now started happening even when I am not gaming that lease renew thing happens and I lose internet til I unplug my ethernet and plug it back in. I feel like whatever is happening is getting way worse and quick.
Have you set a IP address reservation for your PC ON the router?
Is QoS enabled or disabled?
Is others using internet bandwidth when you gaming?
gnemelf wrote:I has now started happening even when I am not gaming that lease renew thing happens and I lose internet til I unplug my ethernet and plug it back in. I feel like whatever is happening is getting way worse and quick.
Not sure on the ip address reservation, qos is enabled with all ports manually added for destiny 2 as priotized, no I am the only device that takes any bandwidth while gaming
