JoeFI's avatar
JoeFI
Apprentice
Jan 15, 2021
Kicked from dashboard
Hi,
I keep getting kicked out of my router dashboard with the message I'm signed in from another device and to either continue or exit. The ex770 is on my network also. It has happened about once a month since I got it but I started using a hybrid vpn yesterday and it happened 4 times last and once today.
  • Are you using either the Nighthawk or the DumaOS app at all? Have you left the interface open on any devices - I'm assuming you haven't? Is it on the VPNd device you notice it?
    • JoeFI's avatar
      JoeFI
      Apprentice
      Hi,
      I do have the nighthawk app on my phone but I can't recall ever signing in to the interface on it. It's on my pc where I get kicked out. I use the vpn on my Playstation.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Do you usually access via routerlogin.net or the LAN IP (default 192.168.1.1)? Do you notice a difference connecting to either?
