Tendrop
Aug 03, 2019Aspirant
LAN Issues and Slow Geo-filter
Despite at least one factory reset, rolling back the firmware and setting static IPs, I continue to have issues with the LAN connections which are direct from router to an xbox one x and a desktop computer. I have to reset the router frequently to get them reconnected to the internet. Factory resetting is a slow and painful process with this equipment and I'd rather not unless I absolutely have to!
Also experiencing very slow geofilter while pinging the server or peer whileplaying xbox. I get the "spinning beachball" for long periods. Many times no peers or servers are displayed on the map.
Specs below:
Model XR700
Firmware v1.0.1.10
Fios Gateway Modem - Gigspeed
Any suggestions are welcome. Thanks in advance for your help
- -Donovan-Luminary
There's a new Hot-Fix you can try here:
https://kb.netgear.com/000061118/XR700-Firmware-Version-1-0-1-18-Hot-Fix
Or you can sign up to the beta program here:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR700-Beta-Firmware/m-p/1760800#M11125
Note: Make sure you perform a factory reset right after you update your firmware.
