Noah-needs-help
May 31, 2021Aspirant
Missing settings in xr450 DumaOS
I’ve been seeing you tubers and other people go over the different settings in DumaOS and I have the xr450. Settings like ping hotmap, connection benchmark, addblocker traffic controller, and rapp sto...
Netduma-Fraser
Jun 01, 2021NetDuma Partner
You can find the DumaOS 3.0 beta here: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/New-Firmware-v2-3-2-120-XR450/td-p/2071197 which will bring you the majority of those new options. I would recommend doing a factory reset after the upgrade for a fresh install.
Noah-needs-help
Jun 01, 2021Aspirant
do I do a factory reset in DumaOS after downloading the new firmware update or do I need to do the pin on the back of the router?
- Netduma-FraserJun 01, 2021NetDuma PartnerOnce you have upgraded you can do a factory reset from the interface, no need to use the pin
