Hn7r's avatar
Hn7r
My internet goes down every night at 2AM
Hi,
So i recently got the xr500 gaming router and Now every time around 2am my internet goes downhill, I get disconnected from my stream, and I lag in game. It lasts for the rest of the night. Any suggestions?
  • FURRYe38's avatar
    What is the front Power, Internet and WiFi leds showing when this happens? Any of them Amber in color?
    • Hn7r's avatar
      Hn7r
      I’m updated to the newest firmware, and the NG router is connected to a fios gateway router. I’m on auto 5 ghz channels but only cause none of my neighbors use 5GHZ but me .
      I will take a pic of the front LEDs tonight when it happens and let you know
      • FURRYe38's avatar
        Modem Combo Units:
        This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
        Couple of options,
        1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
        2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
    • Hn7r's avatar
      Hn7r
      The lights on the front didn’t show Amber. Just the normal white colors.
