Mgueddi
Sep 30, 2020Follower
My router keeps cutting internet
I have to reboot my router multiple times a day becuase it keeps dropping connection. Everything is wokring one second and then all of my devices are unable to use the internet. This is temporarily fixed by a reboot but I was wondering if anyone knew a more permanent solution to this issue. I would post my logs here but I'm new to this and do not know what is safe to post.
What firmware are you on?
What modem are you connected to?
Is it wired devices that drop, wireless, or both?
- Netduma-FraserNetDuma PartnerPlease try the XR500 3.0 beta and let us know if you get the same issues on that firmware. Would suggest doing a reset after you've upgraded to prevent any legacy issues carrying over. https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/bd-p/en-home-beta-npg-duma
