blackshirt40
Feb 04, 2019Guide
my wired pc doesnt show in dumo
most of the time, the dumo os doest see my wired pc, in the network monitoring section or the network map, also when are you guys going to fix the pc settings in dumo so we dont have to change our pc to a console...
- Netduma_JackNetDuma Partner
We have fixed the need to change PC to console in our current development version (for Fortnite, which is the most common reason to need to do this).
Network Monitor shows the top 5 devices using the most bandwidth. So if you cannot see it, I suspect it's because it's not using much bandwidth at the time. If you want to be able to see it, download something on your PC e.g. a YouTube video, and it should then show.
even running a speed test on my pc wont show it, and in the device manager it shows my pc off line and not connected to lan, everything works fine i guess its just a bug, ill check again but if i remember correctly not having my pc as a console wont trigger qos traffic priorataztion when i play league of legends
- Netduma-FraserNetDuma PartnerHow do you have your PC wired to the router, is it through a switch or router before connected behind the XR500?
