fatpigpigboy
May 16, 2020Aspirant
Need Help for XR700 no 2.4/5G wifi after suddenly shutdown
Hello to all forum members.
I really need a help now. My XR700 suddenly shutdown and i just re-power it . After that , there were several issues:
1. There is no 2.4G / 5G wifi after re power on. Whatever i clicked software or button . No LED light on , no wifi signal. Only 60G wifi light on only
2. Cannot load into Duma OS Systems ( DumaOS not loaded yet!). Whatever i upgrade or downgrade firmware , same issues.
Please advise.
Thx , P.
- Netduma-FraserNetDuma PartnerDo a factory reset by holding the button down in the back of the router for 30 seconds, then let go, wait a minute then connect to the interface and do the setup wizard. Does it work properly after that?
- fatpigpigboyAspirant
tried , same issues. Only can use with wired port . Wifi still no functions. DumaOS still no access.
Thanks.
- Netduma-FraserNetDuma PartnerHow are you trying to access the interface? Can you access using routerlogin.net or the LAN IP? If neither does it work if you access using routerlogin.net/adv_index.htm ? If so factory reset from there instead.
