xReddys's avatar
xReddys
Initiate
Dec 15, 2023
Need help on suspicious logs [LAN access from remote]
I been looking at my router logs recently and been seeing a lot of [Lan access from remote] logs that I can show. I've done my search on this topic and seem it could be someone trying to access my network. I already have UpNp Disabled still seeing remote logs happening another advice was to disable DMZ, or Admin Administration which I'm thinking I haven't done. I'm running #DumaOS and don't see anything about DMZ nor Admin Administration in my advanced settings. Need help on how to protect my Network, and have my Network as safe as I can.
Here are the Logs that are being run;
[LAN access from remote] from 91.92.250.231 port 53377 to iPhone IP port 3392 Friday, Dec 15,2023 10:44:47
[LAN access from remote] from 79.124.58.130 port 54932 to iPhone IP port 3186 Friday, Dec 15,2023 10:43:44
[LAN access from remote] from 77.90.185.62 port 46453 to iPhone IP port 443 Friday, Dec 15,2023 10:43:23
[LAN access from remote] from 162.194.253.194 port 62264 to iPhone IP port 443 Friday, Dec 15,2023 10:43:03
[LAN access from remote] from 167.94.145.21 port 5789 to iPhone IP port 2079 Friday, Dec 15,2023 10:42:38
[LAN access from remote] from 205.210.31.164 port 56272 to iPhone IP port 88 Friday, Dec 15,2023 10:42:22
[LAN access from remote] from 35.203.211.13 port 51131 to iPhone IP port 1445 Friday, Dec 15,2023 10:41:47
1 Reply
  • NG routers can be quite sensitive when it comes to the logs, a lot of times its just connections you've come in contact with. One of the IPs is Google for example. As long as you have Remote Management disabled in settings (it is by default) no one can access your router
