Wyzfar's avatar
Wyzfar
Netduma r2
Does anyone know if the netduma R2 has the same issue in device manager where the software does not recognize the device being on when it is. with the nighthawk XR Series specifically still in the current version 2.3.2.114. still having this issue even though Netgear has pushed out firmware updates to "Fix" this problem not only that but DumaOS 3.0 was announced by netgear over a year ago and it is still in beta. highly considering the Netduma R2 to replace my Nighthawk Xr500 "Pro Gaming Router"
  • plemans's avatar
    You'd be better to ask in the netduma forum and not the netgear forum.
    As well as you asked this in the nighthawk forum and not the pro-gamer forum where some of the DumaOS members tend to be.
  • You should upgrade to the .120 beta version for the XR which has made this better, as far as I'm aware the R2 doesn't have that issue
