z-ej's avatar
z-ej
Tutor
Jul 14, 2020
Netgear R7000 on Xbox problem
Alright so I’ve searched the forum and haven’t found my specific problem yet.
I have my Xbox One X directly connected to the router so it’s not a WiFi issue. My internet provider goes above 500Mbps but ever since I have had this new router the max I can get is around 120Mbps. Obviously directly connected it should be the fastest device on the network but wifi on 5g has tested faster than that (up to 300Mbps). I’ve tried different router settings, enabled QoS, and prioritized the Xbox as highest priority. I’ve also tried different Ethernet cables and also directly connected the modem straight to the Xbox (which tested at 500Mbps so I know it is the router). What am I missing here?
  • plemans's avatar
    What modem are you using?
    What firmware is it on? The agreed upon stable version for the R7000 is 1.0.9.42
    Qos isn't recommended at speeds >250mbps. just an fyi.
    • z-ej's avatar
      z-ej
      Tutor
      The modem I have is from Spectrum E31N2V1
      Firmware for the router is 1.0.9.88_10.2.88
      • z-ej's avatar
        z-ej
        Tutor
        I went through my router settings again. Disabled QoS and enabled IPv6 which helped a little. Up to 180Mbps now but still not as high as I want it to be for a directly connected device. WiFi is still faster.
