GS3339's avatar
GS3339
Guide
Sep 27, 2022
Netgear Xr 1000 wifi problem
Hello,
I have a big problem with my Router..
For example we watch TV at night youtube netflix etc... than close tv sleep and in the morning tv has no connection with wi fi?? Wtf is that? My mother use her phone normal at night go work come back and somehow her phone cant connect to the Router.. why is happening that? To fix that i am restarting router than the phone tv etc are able to connect again but i wanna know why this happens how to fix it... so annoying restarting router every day 3 4 times
  • Disable Smart Connect for WiFi and manually connect devices to 2.4 or 5GHz and see if that resolves the issue please
    • FURRYe38's avatar
      How is Basic and Advanced wireless settings configured on the router?
      What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
      Be sure wifi adapter drivers are up to date on the laptop.
      Might try disabling AX and OFDMA on the router.
      Set 40Mhz only co-existance.
  • plemans's avatar
    what modem/gateway do you have?
    Also, what exactly is it doing? Is it saying "connected, no internet", is it not seeing the wifi broadcasting at all? Is it broadcasting but devices can't connect to it?
  • Hey guys thanks for the answers..
    Smart connect is disabled i read some topics but it didnt fix the problem
    - on phone it says can not get ip adress,
    - on tv is same you can see the wi fi and it says that is connected to wi fi but no internet
    • GS3339's avatar
      GS3339
      Guide
      The internet is in Germany i use SVDSL internet with Fritzbox in germany the XR1000 is connexted to the fritzbox 7530
    • Netduma-Liam's avatar
      Netduma-Liam
      NetDuma Partner
      Are any devices connected to the XR via wired? If so, are they able to access the internet when the problem occurs? Can they reach the DumaOS interface by going to 192.168.1.1 in the web browser?
      • GS3339's avatar
        GS3339
        Guide
        Hey,
        There is no problem with Wired connected like PS5, Pc they are always ok , only have problem with wi fi conncted gadgets tv, phone interesring thing is my Mother phone is old Lenovo, and she always have problems, my and my wife samsung phones dont have that problem, and the 2 TV are facing this problem always
