TealITGyrl's avatar
TealITGyrl
Netgear_XR1000 Odd behavior once a month, upon reboot it factory resets!
I have had the router since January 31st 2022. I've had to reboot this router at least 5 or 6 times. Everytime it's because either my devices randomly drop (usually my PS4 and Amazon Firestick). This time I used the WPS button and it connected with a AIRPA address. When I tried to log in to the admin console I get this below. I see this has been an ongoing issue with no real resolve. I even did a backup and tried to restore and it didn't work. Everytime it reboots I loose all of my network configs.
haserl CGI Error
Failed to readline from 'config get DumaOS_Theme_Version'
System Info
Nighthawk Pro Gaming 6-Stream WiFi 6 Router (XR1000) - AX5400 Wireless Speed
System InfoUptimeRouter TimeTime ZoneBoard ModelFirmware VersionDumaOS Version
1 hour 18 minutes 56 seconds
Tue Mar 22 19:35:05 2022
(GMT-5:00) Bogota, Lima, Quito
XR1000
1.0.0.58_1.0.44
3.0.216
1 Reply
  • Could you please try going to the LAN settings and change the minimum DHCP pool address to be .50.
    Then go through the reserve IP addresses for each device that struggles maintaining a connection. Reserve address in the range of .2 to .49. Let us know if they still have troubles.
    With regards to the error you're seeing, Could you disconnect the wireless device and remove it from Device Manager. After that, connect it back to the XR normally with wireless password auth instead of WPS. Do you still have the same issue trying to get to the interface?
    How are you rebooting the XR, via the button on the back or through the DumaOS interface?
