chedyus's avatar
chedyus
Tutor
May 27, 2020
Netgear XR300 Geo Filter
Hi everyone, so i just purchased an netgear xr300 router and i just can t use the geo filter setting, is not working for me and i don t know what else to do i tried everything, even the filtering mode option can t be accessed ... can someone please help me?!?!
see print screens https://imgur.com/a/tX6NoLE
thank you
  • We need to update the Source Engine service so this is a workaround, we'll have it sorted for the next firmware.
  • Remove the device from the Geo-Filter and then change your PC to an Xbox or PlayStation in the Device Manager and then re-add it to the Geo-Filter, it should work then.
    • chedyus's avatar
      chedyus
      Tutor
      it does work like that, thank you so much... it is a bug?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
