Gkontos10's avatar
Gkontos10
Netgear Xr500 cant get full speed
Hey guys
I finally got a used XR500
After a factory reset i manage to make it work...
But i face a huge problem... I cant get full speeds on XR500 but i did on through my modem.. (my provider modem its an ARRIS TG2492 and its bridge mode as i used it for Netduma R1 router)
From the modem I 138mbps
And from XR500 78mbps
Both connected with cable
That is a huge difference..
Also the other settings are
Antibufferbloat its at 100%
Also it set on "when high priority traffic detected"
Secondly i set my speeds manually at 120 down and 7 up as the package i paid...
Firmware said that is updated to the latest version..
So also a fast rewind
1. I test speed through modem and i got 138mbps download
2. At the setup wizard when netgear test the speeds, it gaves me 138mbps download
3. After finish the wizard i test again and i got 76 (i tested multiple times)
I didn't change anything exept
Geofilter set to Cyprus and filtering mode
I set manually Antibufferbloat at 120 down and "when high priority traffic detected"
Set playstation as high priority through geofilter
Thats all
Can you please help??
  • FURRYe38's avatar
    Under QoS, does the speed for DOWN show 138Mbps?
    What happens if you disable QoS?
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      After going through the setup wizard did you do a speed test and see if you got full speeds or was it only after a few settings you noticed the issue? Have you tried with WiFi as well?
      • Gkontos10's avatar
        Gkontos10
        At the wizard it runs a speed test by it self and it show 138 down, like the speed i got from modem...
        I run a speed test after wizard and set up finish and i got 76 down..
        But i didn't connect anything i just finished the set up...
        At QOS i set it to 120 down and 7 up as the package i paid...
