stricken
Jun 19, 2019Aspirant
NETGEAR XR500 LAN Access From Remote Logs
I know that the logs on DumaOS go wild and lead to a lot of false scares, but I still wanted to double check this. I don't often go into my logs, but I do every once in a while to make sure that there's nothing wild going on. I was looking last night and noticed that I'm getting a bunch of reports for the [Lan access from remote]. I was looking at the IP that they were trying to connect to, but couldn't find any devices with that IP. After a little more looking around, I realized that it was the address listed in my "WAN Setup" tab. Should I be worried? Is there anything that I can do if this is real? UPnP is disabled and I'm not port forwarding. I'm still pretty basic on my understanding of everything, so if we can stick with simple answers, that would be best! I've attached some logs so you can see, and replaced my WAN address.
[LAN access from remote] from 185.176.27.166:49745 to XXX.XXX.X.XX:45604, Wednesday, June 19, 2019 09:53:06
[LAN access from remote] from 81.22.45.29:54266 to XXX.XXX.X.XX:30078, Wednesday, June 19, 2019 09:52:56
[LAN access from remote] from 113.10.192.197:51766 to XXX.XXX.X.XX:23, Wednesday, June 19, 2019 09:52:32
[LAN access from remote] from 185.176.26.105:49564 to XXX.XXX.X.XX:15001, Wednesday, June 19, 2019 09:51:31
[LAN access from remote] from 185.56.81.45:44337 to XXX.XXX.X.XX:8089, Wednesday, June 19, 2019 09:50:58
[LAN access from remote] from 185.176.26.104:46085 to XXX.XXX.X.XX:11015, Wednesday, June 19, 2019 09:50:50
[LAN access from remote] from 92.246.76.48:44073 to XXX.XXX.X.XX:8443, Wednesday, June 19, 2019 09:49:56
[LAN access from remote] from 185.176.27.174:59800 to XXX.XXX.X.XX:3393, Wednesday, June 19, 2019 09:49:44
[LAN access from remote] from 81.22.45.254:48815 to XXX.XXX.X.XX:10018, Wednesday, June 19, 2019 09:49:38
[LAN access from remote] from 185.176.26.27:44301 to XXX.XXX.X.XX:3015, Wednesday, June 19, 2019 09:49:25
[LAN access from remote] from 199.195.251.37:54120 to XXX.XXX.X.XX:123, Wednesday, June 19, 2019 09:47:48
[LAN access from remote] from 109.117.92.2:38758 to XXX.XXX.X.XX:23, Wednesday, June 19, 2019 09:47:46
[LAN access from remote] from 185.176.27.18:49738 to XXX.XXX.X.XX:15704, Wednesday, June 19, 2019 09:47:34
[LAN access from remote] from 178.238.236.106:46358 to XXX.XXX.X.XX:70, Wednesday, June 19, 2019 09:47:02
[LAN access from remote] from 185.176.26.51:50986 to XXX.XXX.X.XX:3210, Wednesday, June 19, 2019 09:46:49
[LAN access from remote] from 89.248.174.167:45096 to XXX.XXX.X.XX:8089, Wednesday, June 19, 2019 09:46:46
[LAN access from remote] from 185.53.91.50:43239 to XXX.XXX.X.XX:5038, Wednesday, June 19, 2019 09:46:45
[LAN access from remote] from 89.248.172.101:46260 to XXX.XXX.X.XX:3389, Wednesday, June 19, 2019 09:46:29
[LAN access from remote] from 185.176.27.70:45769 to XXX.XXX.X.XX:7122, Wednesday, June 19, 2019 09:46:28
[LAN access from remote] from 92.63.194.148:47169 to XXX.XXX.X.XX:47363, Wednesday, June 19, 2019 09:46:13
[LAN access from remote] from 81.22.45.252:43130 to XXX.XXX.X.XX:3087, Wednesday, June 19, 2019 09:45:02
[LAN access from remote] from 185.176.26.51:50986 to XXX.XXX.X.XX:3330, Wednesday, June 19, 2019 09:45:00
[LAN access from remote] from 185.176.26.21:50865 to XXX.XXX.X.XX:8003, Wednesday, June 19, 2019 09:44:27
[LAN access from remote] from 185.176.27.42:44739 to XXX.XXX.X.XX:990, Wednesday, June 19, 2019 09:44:09
[LAN access from remote] from 185.176.27.246:49740 to XXX.XXX.X.XX:33889, Wednesday, June 19, 2019 09:43:34
[LAN access from remote] from 185.56.80.48:43461 to XXX.XXX.X.XX:8089, Wednesday, June 19, 2019 09:42:59
[LAN access from remote] from 172.105.197.151:57246 to XXX.XXX.X.XX:8888, Wednesday, June 19, 2019 09:42:52
[LAN access from remote] from 185.176.27.14:52581 to XXX.XXX.X.XX:12883, Wednesday, June 19, 2019 09:41:45
[LAN access from remote] from 184.105.247.219:49917 to XXX.XXX.X.XX:548, Wednesday, June 19, 2019 09:41:44
[LAN access from remote] from 185.176.27.38:55461 to XXX.XXX.X.XX:12895, Wednesday, June 19, 2019 09:40:51
[LAN access from remote] from 77.247.110.153:5086 to XXX.XXX.X.XX:5060, Wednesday, June 19, 2019 09:40:42
[LAN access from remote] from 212.108.145.112:46137 to XXX.XXX.X.XX:2222, Wednesday, June 19, 2019 09:40:41
[LAN access from remote] from 185.176.27.66:58329 to XXX.XXX.X.XX:7117, Wednesday, June 19, 2019 09:40:30
[LAN access from remote] from 125.64.94.220:46919 to XXX.XXX.X.XX:3524, Wednesday, June 19, 2019 09:40:29
[LAN access from remote] from 107.170.193.44:59544 to XXX.XXX.X.XX:143, Wednesday, June 19, 2019 09:40:16
- Netduma-FraserNetDuma PartnerAs long as you don't have remote management enabled in Advanced Settings then I wouldn't worry at all. Side note but you should have UPnP enabled if you're not using port forwarding.
- strickenAspirant
Netduma-Fraser wrote:
As long as you don't have remote management enabled in Advanced Settings then I wouldn't worry at all. Side note but you should have UPnP enabled if you're not using port forwarding.I don't have remote managment enabled. What had me worried was the serious drop in speed that I had yesterday when all of this was going on. My Apple TV kept buffering, Xbox was stuttering (even with an okay ping), and when I ran a speed test it was lower than it has ever been.
I'm thinking port forwarding will be what I go with over UPnP.
- Netduma-FraserNetDuma PartnerI don't think that would have caused it, could be to do with other factors such as peak time congestion etc. UPnP is easier as all devices require ports so could run into issues if ports aren't forwarded correctly for a device whereas UPnP will take care of it automatically.
