FURRYe38's avatar
New - XR1000 Version 2 - Firmware Version 1.1.0.22 Released - Hot Fix
NOTE:  This FW is for Version 2 of the XR1000 gaming router line. This version of FW is NOT compatible with hardware Version 1 of the XR1000 router series product line. The label under the router should display a XR1000 v2 or version 2 text information on the label.
Security Fixes: 06/21/2024
Download Link:
https://www.netgear.com/support/product/xr1000v2#download
Firmware Update Instructions:
NOTE: It's recommended to factory reset and setup from scratch after applying this FW update.
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
Adjust IP range as needed if you have more than 100 devices.
Be sure to make a backup configuration to file after the router as been setup:
Saves time if a factor reset is needed.
This article applies to:
  • I am getting a 403 Forbidden when trying to download this firmware file.
    • FURRYe38's avatar
      I'm able to download this file using MS Edge in Windows 10x64.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      If you click on the page so you can read the release notes and use the link there it doesn't work for me either. If you click the download button on the download/firmware list then it will work.
      • bmjen's avatar
        bmjen
        Can you provide the direct URL? I've tried both and they are the same URL with the same Access Denied XML page. I've tried this on Chrome and Edge.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    I just tested and I can download the file.
    DarrenM
    • bmjen's avatar
      bmjen
      I was also able to download the file now. Thanks!
