FURRYe38's avatar
New - XR450/XR500 Firmware Version 2.3.3.136 Released
Security Fixes: 03/12/2025
  • Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
XR450:
Download Link:
https://www.downloads.netgear.com/files/GDC/XR450/XR450-V2.3.3.136.zip
XR500:
Download Link:
https://www.downloads.netgear.com/files/GDC/XR500/XR500-V2.3.3.136.zip
Firmware Update Instructions:
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit  https://www.netgear.com/support/product/XR500.aspx#docs
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: It's recommended to factory reset and set up from scratch after applying this FW update.
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
This article applies to:
Nighthawk Pro Gaming (2)
Let us know how it works for you...
  • FURRYe38's avatar
    Did you load this version your XR450 to  check to see actual FW version on the routers web page?
    Gogle wrote:
    Hello. The firmware upgrade version in the downloaded ZIP file is incorrect. It is XR450 V2.3.2.134 -- NOT
    XR450 V2.3.2.136 as it should be.
    • Gogle's avatar
      Gogle
      Both XR450 firmware V2.3.2.134 and
      V2.3.2.136 are exactly the same size:   36.7 MB (38,529,153 bytes).
      That likely would not be the case if they were different.
      I got the v...136 zip file from the router's page on Netgear's website.
      The router indicated it was v...134.
      • FURRYe38's avatar
        Thank you for confirming that. I've passed this on to NG. Hoping they can resolve it soon.
  • Hello. The firmware upgrade version in the downloaded ZIP file is incorrect. It is XR450 V2.3.2.134 -- NOT
