Netduma_Jack
Sep 08, 2018NetDuma Partner
New Firmware for XR500: 2.3.2.32 (fixes disconnection issue)
You can download here: https://kb.netgear.com/000060127/XR500-Firmware-Version-2-3-2-32
New features and enhancements:
- Improved the Smart Connect feature
 - Supports USB printers.
 - Supports WiFi HT160 for Korea and Japan.
Bug Fixes:
- Fixes security issues.
 - Fixes the disconnection issue for wired devices.
- Swc37Aspirant
So the firmware is older than the updated on and I am still having issues. I did not install the older firmware though since it was older. Any other suggestions why I keep getting kicked off and have to reboot my router every day?
Did you install this version manually and continue to use the router or was a factory reset performed after installing this version and setup from scratch?
 - Netduma_JackNetDuma Partner
Could you try manually installing this older firmware - it will then identify whether the cause of your disconnects is just in the latest firmware (so a software problem), or if it's in both (so more likely to be a hardware problem). Thanks.
Is this the same version of last year? 9/7/2018?
Bug Fixes:
