shunk's avatar
shunk
Tutor
Aug 27, 2022
Next firmwar xr 500
I would just like to know when the new firmware for the xr 500 will be released and if there will be a resolution of the dhcp bug and if there will be ping assist functionality
    • shunk's avatar
      shunk
      Tutor
      Oh sorry I meant the auto setup of the congestion control for optimise my fiber connection not ping assist sorry
      what would you recommend for the congestion control for a 950/800 connection
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Ah yes that will be in the next version I believe. We always recommend 70% as a starting point for both download/upload and then if you continue to have local congestion then experiment with the values until you find what works best for you.
