ajharman's avatar
ajharman
Follower
Sep 07, 2019
Nighthawk Android App
Not sure if this is normal but when I open up the Nighthawk app on my phone and go to Devices it shows all of them by name but under each one it also has UNKNOWN under the name of the connected devices. Is this normal?
  • Could you provide us a screenshot of this please? Also what firmware is the XR500 on?
    • Greynomand's avatar
      Greynomand
      Tutor
      Hi, thankis for the response. I have attached a screen shot for you. The firmware for my XR500 is V2.3.2.56
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        I assume that would show the IP address usually. May be an app bug. Do all the devices have internet and are working normally? If you access the interface is it working correctly?
