melmorkae's avatar
melmorkae
NightHawk Gaming XR500 Router
I received an email stating that I need to update my firmware. With that being said I cannot log on via admin, even tried to reset router and tried again. Now what can I do ? I can't get in to the router via Admin? My app only allows for admin log in, and my tech support ended in 2020. Does that mean a $500 router only lasts four years, will I need to get a new one? Can someone please help me.
  • plemans's avatar
    Are you logging in through the browser?
    The defaults logging in through the browser are
    login: admin
    password: password
    All lower case.
    • melmorkae's avatar
      melmorkae
      Which browser are you talking about? I have tried thru my Nighthawk app, also tried routerlogin.net & neither will let me in.
      • FURRYe38's avatar
        MS Edge or FireFox should work after you factory reset the router and setup from scratch with a wired PC and either of those web browsers pointed to 192.168.1.1...
  • What are you seeing when you try to access the DumaOS interface by going to 192.168.1.1 in your web browser? Are you being prompted for a login, but can't remember your username/password?
    If so, since factory resetting, please clear your browsers cache or try accessing the interface from an incognito/private window. Are you then able to access the setup wizard again?
