SHale0824's avatar
SHale0824
Follower
Apr 13, 2020
Nighthawk R6900v2 Slow Speeds
Testing my routers speed from my app it is recieving 140-170 mbps download speeds.
I updated the firmware and the current version is v1.2.0.62_1.0.1
I factory reset my router and turned off smart connect.
When I connect my PS4 to the 5ghz wifi or 2.4ghz i am getting 5-20mbps.
I have tested over and over. Sometimes I will get up to 80mbps however my gameplay experiences packet loss and latency issues.
When I bypass my router and connect directly to my modem, I immediately get the 150mbps and no packet loss or latency issues.
I feel as though I shouldn't have to go tweak a bunch of settings in order to obtain the speeds and such advertised on the packaging.
1 Reply
  • plemans's avatar
    What modem are you using? (brand and model)
    How are you testing speeds? Game servers aren't reliable speedtest sites.
    look at speedtest.net or dslreports.com to test speeds.
