nuubje006
Oct 18, 2019Star
Nighthawk RMX570 - Wifi is working but dashboard says it is disabled
Hello, The sahboard says my wifi 2.4 and 5 GHz are disabled. Even though I do get wifi. The wifi connection is also pretty bad. Not sure what is causing this as it seems to be perfect start of the...
Oct 23, 2019Guru - Experienced User
Can you connect a wired PC to the XR router and factory reset the XR router and walk thru the setu wizard with the PC and a web browser. Try Opera.
What FW version is loaded on the XR router and EX extenders?
What is the distance between the router and satellite(s)? 30 feet is recommended in between XR and EXs to begin with depending upon building materials when wirelessly connected.
nuubje006 wrote:Hello,
The wifi connection is also pretty bad. Not sure what is causing this as it seems to be perfect start of the week. (Right after the first installation)
The firmware is up-to-date.
Here are some pics of what I see in the dash:
I appriciate any help :)
Kind regards.
- nuubje006Oct 23, 2019StarThank hou for the reply. For now I Got it to work by redoing the complete installation. The firmware was the latest i could download last week. Not at home so I can't check. But I looked at the version so I'm pretty sure.
Next time I run into those problems I will try it this way. The problem is that I also have another modem provided by my Internet provider.
I have 3 stories in my home modem is at the lowest, my netgear is at the top and my extender in the middle. I have 300Mbps dl and 20Mbps up.
It all works fine now. My modem connects to my netgear to my pc. My printer is on the wireless (all have the same name and pw)
Now for some reason my pc does not see the printer on the network.. Networking is confusing and hard xD if I look at the dashboard I can see all devices connecting just fine..
Weird stuff :p- FURRYe38Oct 23, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the XR router is connected too.
Probably need to reconfigure the printer and your PCs printer drivers for the new IP address the printer gets from the XR router. Refer the printers user guide to set this up again. Be sure you use updated printer drivers.
IF the system is up and running, be sure to do a backup configuration to file for safe keeping. If you have to do a factory reset, then you can just load the backup from file and be up and running fairly quickly.
- Netduma-FraserOct 23, 2019NetDuma PartnerThe extender, is it actually an extender in that you can see ALL the devices connected to it on the Device Manager? Does the printer have a screen or anything where you can see its IP and then find that on the Device Manager? It may be named differently to what you are expecting.
