nuubje006
Oct 18, 2019Star
Nighthawk RMX570 - Wifi is working but dashboard says it is disabled
Hello, The sahboard says my wifi 2.4 and 5 GHz are disabled. Even though I do get wifi. The wifi connection is also pretty bad. Not sure what is causing this as it seems to be perfect start of the...
Netduma-Fraser
Oct 23, 2019NetDuma Partner
The extender, is it actually an extender in that you can see ALL the devices connected to it on the Device Manager? Does the printer have a screen or anything where you can see its IP and then find that on the Device Manager? It may be named differently to what you are expecting.
nuubje006
Oct 23, 2019Star
Will I only have 1 thing from HP so I think it is the printer. But it seems to keep going to offline, I'm going to restart and try it again. I can't see the IP of the printer as it doesn't have a screen. But I was able to find an IP of the HP item in my router and I could ping it. But still it stays offline. Dunno ;p The one thing in IT that is rocket sience for me is networking.
Guess I need to start over and disable all devices to start with and add them one by one.
- Netduma-FraserOct 23, 2019NetDuma PartnerIt may be going offline as I assume it goes into standby until you start a print job. Is there anyway you can turn it off standby or see if when you turn it off and on again if it comes online properly. Then check if you can wirelessly print, if so then may be something to do with standby.
- nuubje006Oct 23, 2019Star
It used to work wireless, but even that is not working. Never tried it before I had the nighthawk with my pc. But I will try connecting it with an ethernet cable and see if I can somehow get it to work wireless later if I start over again.
Thanks for the help!
- FURRYe38Oct 23, 2019Guru - Experienced User
What is the model of the printer?
nuubje006 wrote:Will I only have 1 thing from HP so I think it is the printer. But it seems to keep going to offline, I'm going to restart and try it again. I can't see the IP of the printer as it doesn't have a screen. But I was able to find an IP of the HP item in my router and I could ping it. But still it stays offline. Dunno ;p The one thing in IT that is rocket sience for me is networking.
